Fit 160 minutes on DVD
Dave Raizman
on Aug 19, 2010 at 1:47:32 pm
I'm using Compressor to try to compress 160 minutes of footage (a play) onto one SD DVD. When I bring the files into DVD Studio they're just a little too large to fit on the DVD.
Does anyone know how to tweak the settings in Compressor so that I'll be able to get the files small enough to fit?
Dave
Chris Blair
Re: Fit 160 minutes on DVD
on Aug 20, 2010 at 2:21:35 am
Use a bitrate calculator to determine what data rate you need to fit it. 160 min. should fit on a DVD, albeit at a relatively low data rate.
There's a bit-rate calculator you can download here:
http://www.videohelp.com/BitrateCalc.zip
Chris Blair
Magnetic Image, Inc.
Evansville, IN
http://www.videomi.com
Read our blog http://www.videomi.com/blog
