Compressor 3.5 Default Settings NOT TAKING!
Nathan Tinsley
on Aug 11, 2010 at 7:37:30 pm
I've been using Compressor for about a year now and I love using the preferences to set up a default setting and destination for my exports. So now I've upgraded to FCS3 and Compressor 3.5. I set up my preferences the same way.... only it doesn't work! I've checked it several times, made several different selections and yet when I to a SEND TO --- COMPRESSOR, the timeline shows up in the batch window with NO DEFAULT settings on it. I looked at the other check boxes in the preferences dialog but none seem to help. What am I doing wrong?
Karen Schwarzer
Re: Compressor 3.5 Default Settings NOT TAKING!
on Aug 11, 2010 at 8:46:41 pm
A note here - I work with Nathan and If we import a file into Compressor - then the default setting appears. But if we "send to" compressor from FCP 7 the setting doesn't appear.
Tony Florio
on May 16, 2011 at 8:19:35 pm
Wow, my exact problem, yet no solutions posted for it in several months. Darn, I wish someone knew how to fix this! It worked before and it's a HUGE pain in the butt, and worse, the view windows for "SETTINGS/DESTINATION" doesn't stay open either, making if MORE steps to do this procedure.
Craig Seeman
on May 16, 2011 at 8:38:27 pm
So many people have found Send to Compressor unreliable. You could try tossing your preferences. You could hope that with FCPX Apple has found a better way.
Ron Beyers
on Aug 5, 2014 at 1:58:54 am
3 years after the last post, and still the problem persists. Hoping it's solved when using FCPX.
