MPEG-2 to DG Fastchannel
Samuel Smith
on Jul 30, 2010 at 12:09:47 am
Wanting to use DG Fastchannel's dropbox for delivery of our spots instead of sending a digibeta out everytime. Here's the spec sheet they sent me - Does anyone know which programs can achieve this (preferably something cheaper than squeeze or Episode)?
Encoding . . . MPEG-2
Preferred. . . . 18Mb/s
Scanning. . . 480 60i (upper field first)
Pixel Aspect Ratio. . . . . . . . . . . 0.9
Aspect Ratio. . . 4*3
Chroma. . . . . . . . . . 4:2:2 (MP@ML) (720*512)
GOP. . . All Allowed, IBBP preferred
Frames per second. . . . 29.97 (NTSC)
Stream Type . . . Program Stream
Audio – MPEG-1, Layer 2 . . . . . . . . . . 384Kb/s Stereo
Audio – Dolby AC3 . . . . . . . . . N/A
Digital Audio Level*. . . –20dBfs
Luminance Level Max. . . . . . . 100 IRE
Chroma Level Max. . . 120 IRE
Setup level. . . 7.5 IRE
Timecode. . . Not Used
THANKS!!!
Craig Seeman
Re: MPEG-2 to DG Fastchannel
on Jul 30, 2010 at 12:20:52 am
Telestream Episode and I have a preset as well specifically for DG which I've been using to deliver spots for years. If you're delivering spots you should be able to afford Episode. There are very few encoders that will insert the proper Vertical Blanking interval to get a 720x480 or 720x486 to 720x512. If you're getting a 15% agency rate for doing the media buy all it takes is about a $3000 buy to pay for Episode.
Samuel Smith
on Jul 30, 2010 at 1:07:20 am
Okay, thanks for that! Would it be necessary to buy Episode Encoder Pro? Or could I get by with just Episode Encoder?
Craig Seeman
on Jul 30, 2010 at 2:13:22 am
Standard is fine for DG setting.
