best export settings MPEG streamclip - DVD to AVI via FCP
emma sullivan
on Jul 21, 2010 at 6:50:54 am
Hi there,
I have a number of DVDs to edit in FCP and then eventually play on media players (Patriot Box Office) for a museum exhibition. I thought to use MPEG streamclip to export the DVD as DV to then import into FCP and eventually export as a .mov. However the resulting file cannot be played in the media players.
If i was to then bring that .mov file back into MPEG streamclip and export as an .avi would there be a noticeable loss in quality?
What would be the best settings in MPEG streamclip to ensure best quality .avi
Thanks in advance!
Daniel Low
Re: best export settings MPEG streamclip - DVD to AVI via FCP
on Jul 21, 2010 at 8:57:36 am
[emma sullivan] "and eventually export as a .mov. However the resulting file cannot be played in the media players."
What kind of .mov? Mov is just a wrapper - what codec did you use?
http://www.patriotmem.com/products/manuals/boxoffice/BoxOfficeManual.pdf
Sent from my iPad Nano.
emma sullivan
on Jul 21, 2010 at 11:40:12 pm
I think its DV-PAL.
Would it be better to use something like H264? or MPEG-4 Video? - I can see now on the Patriot Manual that these are supported
Thanks for your help
Daniel Low
on Jul 21, 2010 at 11:59:24 pm
Yes, certainly worth a try.
emma sullivan
on Jul 22, 2010 at 1:11:10 am
Thanks Daniel, That did the trick!
