Backwards Frame Size
Tyler Mleynek
on Jul 16, 2010 at 3:28:39 pm
I've never had to export anything with a weird aspect ratio but I'm converting a .wmv file to .mov and the aspect ratio is 720x1280. I'm using an HDV720 preset in compressor with flip4mac and turning on 100% of source for my frame size but it comes out backwards (1280x720). I then entered the frame size myself (720x1280) using customs settings and the same issue occurred. Pixel aspect is set to square. What am I missing or is it a quicktime issue? Thanks.
Daniel Low
Re: Backwards Frame Size
on Jul 16, 2010 at 4:47:14 pm
[Tyler Mleynek] "I'm using an HDV720 preset in compressor"
That preset does 1280x720. HDV is not capable of doing 720x1280
Why do you want 720x1280?
Sent from my iPad Nano.
Tyler Mleynek
on Jul 16, 2010 at 6:40:52 pm
Because I'm converting a video that is 720x1280 from wmv to mov. The video was made with that frame size.
Daniel Low
on Jul 16, 2010 at 7:52:18 pm
I'd go for a .mov and use the photoJpeg codec.
Tyler Mleynek
on Jul 16, 2010 at 9:38:08 pm
That was it. Thank you friend. Is there a website or book that I can learn more about codecs? Thanks again.
Daniel Low
on Jul 16, 2010 at 10:21:43 pm
For stuff like this.....no for everything else the http://WWW is the best book in the world.
