How convert in the best way .mov to .swf ?
Gerardo Flores
on Jul 13, 2010 at 6:12:32 pm
hello guys
Im trying to add some interactive in flash to a video that I
already have prepared in a file .mov
can some body advice me witch is the best way to convert and at the same time compress
the file.. from .mov to .flv or .swf .?
I will like to use the result video interaction to upload in a web site
Thank you and
Kind Regards.
Gerardo
learning after effects
Craig Seeman
Re: How convert in the best way .mov to .swf ?
on Jul 13, 2010 at 6:26:39 pm
H.264 .mov works fine in Flash. There's no reason to convert to if that's your source. .swf is the player/wrapper you create when building your interactivity.
Gerardo Flores
on Jul 13, 2010 at 8:01:55 pm
Hi Craig.
Thank you for your comment.
Are you telling me that I can open a .mov in flash and start to add interactions, buttons etc?
Craig Seeman
on Jul 13, 2010 at 9:56:19 pm
[Gerardo Flores] "Are you telling me that I can open a .mov in flash and start to add interactions, buttons etc? "
Yes but the .mov must be H.264. It's the only .mov codec that works natively in Flash. If the file is another codec all you have to do is convert to H.264 though. Just make sure you target the data rate you want but Quicktime Pro, Final Cut Pro, even MPEGStreamclip (free) can do that. Flash became officially compatible with H.264 .mov in Dec 2007.
