Export for flash compression
Jim Mulleder
on Jun 3, 2010 at 7:01:05 pm
Hello compression artists,
I have a client that wants uncompressed files for flash compression to be used in an on-line learning environment. Most of the video is talking heads shot in DV widescreen. My 20 second export out of FCP was 550MB at around 230MB/second, 8 bit uncompressed. I don't know if we are really gaining anything using such high data rates at 720x486 when this is going down to flash anyway. I know garbage in,garbage out but this seems a little excessive.
What do you folks use when exporting for Flash video?
Thanks all,
Jim
Jim Mulleder
Level Horizon Productions
Cameraman/Editor
778.888.4336
Craig Seeman
Re: Export for flash compression
on Jun 3, 2010 at 7:12:17 pm
You could just export as DV .mov files.
If they were planing to do any heavy compositing before hand, being in a 4:2:2 format might help but otherwise not really.
Jim Mulleder
on Jun 4, 2010 at 6:20:04 pm
Hi Craig,
I did try your recommendation plus and 8 bit uncompressed, the files were only 3GB. I'll let them see if they can see the difference.
Jim
Jim Mulleder
Cameraman/Editor
778.888.4336
