MPEG2 Encoding Problems
Tom Payne
on May 26, 2010 at 1:42:28 pm
I'm trying to encode an MPEG2 D-10 file at 30mbps using Digital Rapids Stream. It encodes fine but when I open it in quicktime (or MPEGSTREAMCLIP) to check it for the clients there is no picture and the framesize is 720 x 408 and it thinks it's a muxed MPEG1 stream. If I open the same file in VLC it plays fine. Below is a diagnostic of the file. Any suggestions?
File: G:/D10 302.mpg
Type: MPEG-2 Transport Stream
File Size: 44550548 bytes
Transport Packet Size: 188 bytes
Duration: 11 sec
Transport Rate: 31001599 bps
program_number: 1
PMT PID: 0x01E0
PCR PID: 0x01E1
Program Descriptors: none
Number of PMT Entries: 2
MPEG-2 Video Elementary Stream
PID: 0x01E1
stream_type: 0x02, MPEG-2 Video
Descriptors: none
stream_id: 0xE0, MPEG Video
Bit Rate: 30000000 bps
Profile: 422
Level: Main
Frame Rate: 25 fps
Resolution: 720 x 576
Aspect Ratio: 4:3
MPEG Layer 2 Audio Elementary Stream
PID: 0x01E2
stream_type: 0x03, MPEG-1 Audio
Descriptors: none
stream_id: 0xC0, MPEG Audio
Bit Rate: 224000 bps
Sample Rate: 48000 sps
