Which format to use for video? USB 2.0 Distribution
Xavier de Champs
on May 21, 2010 at 3:14:18 pm
Hi. I´m doing some showreel distribution on USB keys. I´m looking for a codec, that will stream of the USB being compatible with..say...USB 2.0 HiSpeed.
The original footage is DV-PAL coded into Prores footage.
I need it to run on both PC and MAC, and be playable with standard players.
Question:
1. Is there a format, which will play with default installations on both OSX and Windows?
2. If not. I will make two different files, and label them OSX and Windows. But which format for each, taking into account the transfer speeds of a USB port. I would prefer to be able to play directly of the key, without the customer needing to copy the materal onto HDD.
3. Any other things I should worry about?
PS.
I´m using Compressor or Mpeg Streamclip to compress the file.
Daniel Low
Re: Which format to use for video? USB 2.0 Distribution
on May 21, 2010 at 5:41:47 pm
[Xavier de Champs] "1. Is there a format, which will play with default installations on both OSX and Windows? "
If you want to cover ALL bases use MPEG-1.
[Xavier de Champs] "2. If not. I will make two different files, and label them OSX and Windows. But which format for each, taking into account the transfer speeds of a USB port. I would prefer to be able to play directly of the key, without the customer needing to copy the materal onto HDD. "
This is more about data rate than format check out the transfer specs of USB 2.0 and decide. I'd maybe do one WMV and the other would be H.264 MP4.
[Xavier de Champs] "3. Any other things I should worry about? "
Sent from my iPad Nano.
Xavier de Champs
on May 23, 2010 at 11:54:59 pm
Does Leopard and Snow Leopard come standard with the h.264 codec?
Daniel Low
on May 24, 2010 at 7:48:51 am
Yes they do.
