24p reverse telecine using Compressor?
Tory Stewart
on May 10, 2010 at 12:05:22 am
Hi all,
I want to use Compressor to remove the pull-down on some 24p footage and also convert it to ProRes (in order to work with it alongside some existing ProRes footage) but I'm not sure which settings to use. I have run some tests using the "Apple ProRes 422 for Progressive" settings, checked "reverse telecine" and specified the frame size I need. This results in a file that integrates seamlessly into my ProRes timeline in FCP without requiring any rendering but looks noticeably interlaced and consequently not so good when I play it back. Is this because I've used the wrong settings in Compressor? Should I have used the "Apple ProRes 422 for Interlaced" settings?
Tory
Andrew Saliga
Re: 24p reverse telecine using Compressor?
on May 20, 2010 at 5:15:16 pm
This should guide you along. Let me know if you need additional help.
http://www.kenstone.net/fcp_homepage/preprocessing_hodgetts.html
-Andrew Saliga
Steelehouse Productions
http://www.steelehouse.com (undergoing a much-needed redesign)
http://www.vimeo.com/steelehouse
