Target File Size
Faraz Mozafarian
Target File Size
on May 7, 2010 at 6:26:21 pm
Are there any programs out there where you can simply enter a target file size and the software will figure out the compression settings for you and export. I am currently using compressor.
Craig Seeman
Re: Target File Size
on May 7, 2010 at 6:47:48 pm
Google BitRate Calculator and you'll find scores of them. Some are targeted for specific uses.
http://www.google.com/search?client=safari&rls=en&q=bitrate+calculator&ie=U...
I believe Squeeze has a file size parameter. Compressor will give you an estimated size so you sort of have to work backwards and drop the bitrate if the size is too large.
