 | Compressing 24fps to Mpeg-2 for DVD
on Apr 22, 2010 at 7:30:20 pm |
I'm surprised I couldn't find the answer to this on here already, but I was searching through the forums and didn't locate it. I apologize if I just missed it.
I'm currently working on editing a project that I didn't shoot. I'm working in FCP and After Effects and compressing using the Compressor program. Unfortunately, the shooter decided to shoot in 24fps which wasn't very necessary. But, since that was the native format, I ended up editing the sequence and creating any After Effects sequences in 24fps. When I play the final video on the FCP timeline, it looks great. However, as soon as I compress it, it starts to get really jittery and keeps pausing for a fraction of a second, especially in the After Effects sections. I'm not entirely sure what to do as, when I check the settings on Compressor, it claims that it is using the native frame rate of the file. Any suggestions on what I might be doing wrong?
Thanks in advance,
Sean
 | Re: Compressing 24fps to Mpeg-2 for DVD on Apr 29, 2010 at 1:24:18 pm |
Just wondering if anyone had any solutions to this problem. I'm still having troubles. Thank you.
 | Re: Compressing 24fps to Mpeg-2 for DVD on May 5, 2010 at 3:02:35 pm |
What are you compression settings on the file?
Check the meta data of the file with MediaInfo. This will show you the framerate and all the other useful info when troubleshooting a problem with your compressed file.
-Andrew Saliga
Steelehouse Productions
http://www.steelehouse.com (undergoing a much-needed redesign)
http://www.vimeo.com/steelehouse
