Flipping 35mm footage using compressor
Kevin Ellison
on Apr 22, 2010 at 2:36:35 am
Hi. I have a lot of footage that was shot on a 35mm adaptor, so the videos are flipped and reversed. I know that you can fix this by adding the flop filter in Final Cut Pro and selecting "both", but really want to avoid doing this for two reasons:
1. To avoid the render time
2. To avoid the exporting of these individual clips
I am presenting these clips to clients to review and annotate through Final Cut Server so I need each clip to be individually flipped and compressed to pro res 422 proxy.
Can compressor handle this, or am I stuck using Final Cut Pro?
Thanks.
Daniel Low
Re: Flipping 35mm footage using compressor
on Apr 22, 2010 at 8:55:35 am
Compressor doesn't do DVEs
Sent from my iPad Nano.
