Photo Jpeg blandness in image
Chris Lambert
on Mar 31, 2010 at 10:25:41 pm
Hi everyone
I am currently trying to export XDCAM footage from Avid Media Composer in Photo Jpeg at 95% quality I keep finding that the image is bland and almost desaturated compared to the original image at quite a noticeable way! I have exported as a standard quicktime and put it through Quicktime Pro with the same effect.
is there a procedure that the image must be over saturated before export with this codec or is it a simple settings routine that I have missed?
Any enlightment would be appreciated and I apologise for my limited expression of the technicalities of the subject I am primarily a camera operator and editing is more the hobby. But if there is any more info I can supply consider it done.
Daniel Low
Re: Photo Jpeg blandness in image
on Mar 31, 2010 at 10:43:17 pm
[Chris Lambert] "I keep finding that the image is bland and almost desaturated compared to the original image"
How exactly are you performing your comparisons?
[Chris Lambert] "is there a procedure that the image must be over saturated before export with this codec or is it a simple settings routine that I have missed? "
No. It could be something you've overlooked in your Avid export settings?
Sent from my iPad Nano.
Chris Lambert
on Apr 3, 2010 at 4:53:23 pm
Hi Daniel
Thanks for the quick response my comparisons are currently being performed by exporting an uncompressed quicktime and a photojpg and then clicking between the different quicktime files on the taskbar. (Hardly a technical approach but the results are obvious even to an untrained eye.)
I've experimented around with Avid's setting in the photojpg filter settings but have had no success whatsoever. Any suggestions?
