Encoder Options - AVI Format
Andrew Saliga
on Mar 25, 2010 at 3:57:32 pm
This is sort of a followup to a post I made last week, but new thread since the question is different.
Output request is and AVI encoded with Matrox MPEG-2 I-Frame only codec or uncompressed AVI. From what I can tell, the only requirement is that it must be an AVI, since it's going to be loaded into a Click Effects system for display on a stadium's electronic billboard.
Matrox codecs are hardware locked, so I'm looking into exporting the AVI with MPEG Streamclip on my Mac. Is there a specific encoder I should favor or stray away from? Looking at Wikipedia, it appears the accepted encoders for AVI are MJPEG · Motion JPEG 2000 · MPEG-1 · MPEG-2 (Part 2) · MPEG-4 (Part 2/ASP · Part 10/AVC) · HVC.
-Andrew Saliga
Steelehouse Productions
http://www.steelehouse.com (undergoing a much-needed redesign)
http://www.vimeo.com/steelehouse
Daniel Low
Re: Encoder Options - AVI Format
on Mar 25, 2010 at 4:29:31 pm
If they need i-frame only or uncompressed it's for a reason and as such given them a LongGOP file (the other formats you list are all LongGOP except JPEG2000) is likely to be unacceptable.
It might be worth contacting Click Effects to see what they do support?
Sent from my iPad Nano.
Andrew Saliga
on Mar 25, 2010 at 7:16:01 pm
Now that I look again on the Click Effects site, it looks like an Uncompressed AVI is preferrred, and AVI is the only accepted format.
What I didn't realize is that AE on PC allows you to output an AVI ("Video for Windows"), while it's not even an option for AE on a Mac. Since this project relies heavily on AE plugins, I'll render out a QT Animation from AE on the Mac and use AE on the PC to transcode to Uncompressed AVI.
-Andrew Saliga
Daniel Low
on Mar 25, 2010 at 8:13:45 pm
You can export Uncompressed AVI out of Quicktime Pro 7 on a Mac.
Andrew Saliga
on Mar 25, 2010 at 8:39:03 pm
Nice. I saw that yesterday, but thought it was the equivalent of selecting "None" in FCP when outputting with QT conversion.
Good to know. Thanks Daniel.
-Andrew Saliga
Daniel Low
on Mar 25, 2010 at 11:13:48 pm
'None' in this case means no compression, despite 'CODEC' meaning COmpression DEcompression, a 'None CODEC' is an uncompressed CODEC. Remember both AVI and Quicktime are just wrappers for CODECs.
Andrew Saliga
on Mar 26, 2010 at 2:42:11 pm
Right.
It makes sense that "None" is uncompressed, I was confusing it with the "Video" codec in FCP.
-Andrew Saliga
