sorenson squeeze 6 no audio after render
Jason Barczewski
on Mar 19, 2010 at 5:07:37 am
I've tried a couple of different renders with squeeze 6 and i'm getting no audio.
the preview is fine and plays the audio.
what do i have setup wrong?
i have installed ffdshow.
thanks for any help
Andrew Saliga
Re: sorenson squeeze 6 no audio after render
on Mar 19, 2010 at 5:07:56 pm
I can possibly tell you what you "have set up wrong" if you tell me what you have set up currently.
What does your Squeeze preset look like, what is your source and what is your output?
Here's a thread "sticky" that tells you what you should be posting to get the fastest help.
http://forums.creativecow.net/readpost/20/862073
-Andrew Saliga
Steelehouse Productions
http://www.steelehouse.com (undergoing a much-needed redesign)
http://www.vimeo.com/steelehouse
