Frame Skipping - Video and Audio Desync
Nick Howard
on Mar 10, 2010 at 4:29:55 am
Hi
We are having an issue with one of our video's that was put together using Final Cut Pro
At different parts of the video the image stalls while the audio continues.
Does anyone know what we can do to get rid of this stalling? Is it a setting/s that we need to correct when rendering the final video?
The Mediainfo data is below. Thanks for your help.
General
Format : MPEG-4
Format profile : QuickTime
Codec ID : qt
File size : 1 009 MiB
Duration : 1mn 42s
Overall bit rate : 82.3 Mbps
Encoded date : UTC 2010-03-04 00:41:15
Tagged date : UTC 2010-03-04 00:41:35
Writing library : Apple QuickTime
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : Main@L5.0
Format settings, CABAC : No
Format settings, ReFrames : 2 frames
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 1mn 42s
Bit rate mode : Variable
Bit rate : 80.0 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 25.000 fps
Resolution : 8 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 1.543
Stream size : 981 MiB (97%)
Language : English
Encoded date : UTC 2010-03-04 00:40:55
Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics : BT.709-5, BT.1361
Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Audio
Format : PCM
Format settings, Endianness : Big
Format settings, Sign : Unsigned
Codec ID : in24
Duration : 1mn 42s
Bit rate mode : Constant
Bit rate : 2 304 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Resolution : 24 bits
Stream size : 28.2 MiB (3%)
Language : English
Daniel Low
Re: Frame Skipping - Video and Audio Desync
on Mar 11, 2010 at 11:04:52 pm
[Nick Howard]
"Format profile : Main@L5.0
Format settings, CABAC : No "
Why no CABAC?
I'd say High @4.1 not Main @5.0
"Main Profile (MP)
This profile is used for standard-definition digital TV broadcasts that use the MPEG-4 format as defined in the DVB standard[24]. It is not, however, used for high-definition television broadcasts, as the importance of this profile faded when the High Profile was developed in 2004 for that application."
What's the GOP size?
What are your VBR settings? (Average, low and upper)
Sent from my iPad Nano.
