Compressor Encode Fails
James Dow
on Mar 3, 2010 at 1:45:14 pm
I have a sequence in FCP6 that I send to compressor for encoding to m2v for DVDSP....each time (3 trys) Compressor says that the encode has failed.due to a Quicktime error. First time this has happened to me. What do I check first?
James
JPD
Daniel Low
Re: Compressor Encode Fails
on Mar 3, 2010 at 2:33:36 pm
Instead of send to compressor, make absolutely sure everything is rendered in the sequence then export as a Quicktime Movie using Sequence settings.
Sent from my iPad Nano.
James Dow
on Mar 3, 2010 at 2:43:58 pm
I will try that...thanks, Daniel
I copied and pasted the edit to a new sequence and sent to Compressor.
It just finished, and says successful. Is it technically better to do it the way you suggested?
JPD
