Whether it is interlaced
Alejo Serra
on Feb 21, 2010 at 4:48:11 pm
Hi!
If this is not the appropriate forum to explaining my question, But could find no other and is an issue that has me crazy.
There is some program where I can look at whether a .Avi or a .Mov that I pass is progressive, Interlaced, Deinterlacing? And if it is interlaced know what the correct order?
And could start working with the knowledge that I'm not doing bad
Thank you very much and greetings!!!
Daniel Low
Re: Whether it is interlaced
on Feb 21, 2010 at 9:11:38 pm
Most good transcoding applications will give you that information.
Also look at MediaInfo - if you are on a PC - or Quicktime with Perian if you are on a Mac
Sent from my iPad Nano.
Alejo Serra
on Feb 22, 2010 at 1:52:24 pm
I used MediaInfo and is seeking, Sampling, Color depth, Interlaced...
Thank you very much!
The only thing he says is the correct field order, If lower or upper, As you can know that?
Thanks again
