NOISE and ALIAS in HighRes Mpeg2
francesco glavina
on Feb 11, 2010 at 3:13:02 pm
Hi all. I'm in big trouble with Compressor. I'm trying to export a movie in MPEG2.
I'm using high resolution settings but my videos have an high level of compression, border of sharp objects appear with a lot of aliasing and on dissolve the video flicker.
Someone Can help me?
I post here my settings:
Mpeg2 1920*1080 29.97fps progressive
Teo pass VBR , Best
Average Bit Rate: 30 Mbps
Maximum Bit Rate: 40 Mbps
Daniel Low
Re: NOISE and ALIAS in HighRes Mpeg2
on Feb 12, 2010 at 3:09:16 pm
http://forums.creativecow.net/readpost/20/862073
Sent from my iPad Nano.
francesco glavina
on Feb 15, 2010 at 8:59:53 am
Thanks Daniel.
MacPro 2.8 Ghz Quad-Core Xeon
6GB RAM
Mac OSX 10.5.8
Output from FCP 7.0
1920*1080 (HDTV 11080i 16:9)30fps "no compression" progressive
Compressor 3.5
Settings:
Teo pass VBR , Best
Destination use: playing on PC.
Daniel Low
on Feb 17, 2010 at 12:29:43 am
[francesco glavina] "1920*1080 (HDTV 11080i 16:9)30fps "no compression" progressive "
that makes no sense:
Is it interlaced or progressive?
This is likely where all your problems lie. Is your source interlaced and then you are exporting from FCP as progressive, or what?
francesco glavina
on Feb 19, 2010 at 4:02:24 am
No, it's all progressive. As i writed over. It's from a 3d and all progressive.
