Compressor fails with error -120
Tom Step
on Jan 29, 2010 at 11:04:51 pm
I'm making a stream file from a qt file (exported from fcp) and Compressor fails with Status: Failed: QuickTime error -120. File plays fine in QTPro and FCP. Tried to change output folders, no help. Made new custom setting from apple sets, still no go. Used a file that worked previously, now does not work... Any ideas?
Also is there a depository of QT errors for FCS?
Tom
^__^ A color grade for every project.
dorit grunberger
Re: Compressor fails with error -120
on Feb 8, 2011 at 7:27:15 pm
Hi Tom
Did you ever get an answer to this problem? I too out of the blue am getting error -120, even for projects that worked fine just the day before. It looks like anything I put through compressor is basically failing :-(
Thanks in advance,
Dorit
Matthew Manzano
on Mar 31, 2011 at 4:56:43 pm
http://neasepost.wordpress.com/2009/08/29/hello-world/
dorit grunberger
on Mar 31, 2011 at 6:23:44 pm
I think I ultimately chucked the preferences and restarted the computer. It's been a while so I don't remember, but I'll keep this info handy,
Many thanks,
Dorit
Thanks in advance,
Dorit
