Compressor h.264 quality stuck at medium
Paul Dougherty
on Jan 22, 2010 at 1:33:43 pm
Using the h.264 codec I'm wondering why I can't change the quality from "Medium" in the window called up by the Video Settings button. (It's the same window where you select one vs multi pass.)
"Standard Video Compression Settings" is the name of this window
Thanks in advance for any suggestions.
Paul
Daniel Low
Re: Compressor h.264 quality stuck at medium
on Jan 23, 2010 at 10:20:50 pm
Did you set a datarate, or is one set for you by any chance?
"There's no chance that the iPhone is going to get any significant market share. No chance."
Steve Ballmer To USA Today: 30 April 2007
Paul Dougherty
on Jan 25, 2010 at 1:48:48 am
A datarate was already set, but then I set it much higher than the default as a test and nothing helped budge the "quality bar" budge off "Medium"
Daniel Low
on Jan 25, 2010 at 7:01:46 am
You can set a datarate OR use the slider, not both. Obviously setting an explicit datarate is usually best.
