capturing uncompressed from betacam sp
Fábio Rodrigues
on Dec 22, 2009 at 4:18:06 pm
Hi
I have to capture a betacam sp video-tape uncompressed using blackmagic card by Mac.
But the capturing has had dropped frames.
I've tried to select "drop frames" and "no drop frames",
uncompressed "10 bit" and "8 bit", (I always use NTSC - I',m in Brazil), but nothing changed.
Someone knows what is happening
or which configurations are generally the right?
thanks
Fábio
Daniel Low
Re: capturing uncompressed from betacam sp
on Dec 22, 2009 at 5:31:42 pm
It seems like your Mac system is not fast enough or powerful enough to deal with uncompressed. Why are you capturing uncompressed?
"There's no chance that the iPhone is going to get any significant market share. No chance."
Steve Ballmer To USA Today: 30 April 2007
Chris Blair
on Dec 23, 2009 at 3:35:41 am
We have a Blackmagic system and I believe the checkboxes you mention actually reference time-code (drop-frame and non-drop frame), not anything related to capturing. The only thing you'd have as an option to select upon capturing would be whether to "report dropped frames."
Our Blackmagic drivers have options to abort the capture if there are dropped frames or to continue and report them to the user.
But Daniel is correct about the cause, your drive array isn't fast enough for uncompressed.
Chris Blair
Magnetic Image, Inc.
Evansville, IN
http://www.videomi.com
Fábio Rodrigues
on Dec 23, 2009 at 10:53:59 am
It`s for old archives of a company.
Daniel
