de-interlace in compressor
enrico parents
on Dec 15, 2009 at 10:10:34 pm
Hi
I'm working in a FCP sequence and in the timeline there is mostly progressive footage but also some interlaced, i was thinking of using compressor to de-interlace the whole sequence, do you think I will get some odd results on the material that is already progressive?
degradation perhaps?
http://www.indydoc.it
Daniel Low
Re: de-interlace in compressor
on Dec 15, 2009 at 10:50:39 pm
[enrico parents] " was thinking of using compressor to de-interlace the whole sequence,"
Why do you want to deinterlace?
"There's no chance that the iPhone is going to get any significant market share. No chance."
Steve Ballmer To USA Today: 30 April 2007
enrico parents
on Dec 15, 2009 at 10:59:20 pm
Couse I want to have everything progressive...
So instead of doing it for each clip that is interlaced in the sequence i thought of doing it to all, even if some footage is already progressive.
Daniel Low
on Dec 16, 2009 at 6:30:45 am
Obviously!
To deinterlace everything is lazy and is likely to cause issues.
Why do you want everything progressive, at this stage?
enrico parents
on Dec 16, 2009 at 9:54:56 am
Thanks a lot, i supposed that this one was not the right choice, just lazy!
--Because it's the final stage and want to uniform everything
