Creating MPEG2 in squeeze for DVD Studio Pro?
Jeff Raatz
on Nov 27, 2009 at 3:41:33 pm
I just purchased the Sorenson Squeeze 6 after being continually disappointed with the quality of HD to SD encoded files in compressor in Final Cut Pro 7.
The problem now is that when I try to create a DVD ready file in Final Cut, exporting a quicktime movie with squeeze, it encodes a MPG file. This file is not recognized by DVD Studio Pro as the M2V files are which are created directly in squeeze. Any way to export a MPV file while still in Final Cut??
This will save a step in the process, not needing to export a quicktime reference movie, which of course when working with long format material saves a ton of drive space as well.
Thanks in advance for your help.
Daniel Low
Re: Creating MPEG2 in squeeze for DVD Studio Pro?
on Nov 30, 2009 at 5:08:48 am
[Jeff Raatz] "I just purchased the Sorenson Squeeze 6 after being continually disappointed with the quality of HD to SD encoded files in compressor in Final Cut Pro 7. "
You're not doing it right, do a search through the posts here, compressor is capable of great quality, if used correctly.
"There's no chance that the iPhone is going to get any significant market share. No chance."
Steve Ballmer To USA Today: 30 April 2007
