Mpeg Streamclip - multiple conversions
Alberto Mendez
on Nov 19, 2009 at 10:22:49 pm
Operating System = Mac - Snow Leopard
Conversion Software = MPEG Streamclip 1.9.2
Source Codec (DVD files)
Destination Codec = Highest Resolution Video and Audio that doesn't need to render in FCP
Type of Destination Use = Create Demo Reel in FCP (cut down versions of original Source material), Create Flash Video Versions for Web (Full Length)
I have all of my documentaries I have cut on DVD's. Most of them are about an hour in length and I was hoping to rip them through Mpeg Streamclip into the highest possible file(s) so I can edit them in FCP without rendering the timeline. I have the hard drive space so I would like the files to be uncompressed (highest quality).
I would also like to create flash video files from the original ripped files.
Any advice and/or settings I should use in Mpeg Streamclip would be greatly appreciated.
thank you.
Daniel Low
Re: Mpeg Streamclip - multiple conversions
on Nov 19, 2009 at 11:40:11 pm
What were the DVD's MPEG-2's encoded at?
"There's no chance that the iPhone is going to get any significant market share. No chance."
Steve Ballmer To USA Today: 30 April 2007
"We and Apple are neck and neck and we're chasing the two
other players,"
Steve Ballmer, referring to Nokia and Research in Motion. October 6th 2009
Alberto Mendez
on Nov 20, 2009 at 8:31:49 am
I copied and pasted the Stream info below:
Stream: VTS_01_1.VOB
Path: /Volumes/A080418_00/VIDEO_TS/VTS_01_1.VOB
Type: VOB program stream
Duration: 0:45:00
Data Size: 2.20 GB
Bit Rate: 6.99 Mbps
Video Tracks:
224 MPEG-2, 720 × 480, 4:3, 29.97 fps, 6.57 Mbps, upper field first
Audio Tracks:
128 AC3 2/0, 48 kHz, 256 kbps
Stream Files:
VTS_01_1.VOB (1021.01 MB)
VTS_01_2.VOB (1021.02 MB)
VTS_01_3.VOB (208.74 MB)
Daniel Low
on Nov 20, 2009 at 10:25:51 am
I'd go with the ProRes Codec.
other players,"
Alberto Mendez
on Nov 20, 2009 at 3:02:29 pm
There are several Pro Res Codecs. Which one should I use?
444
422 (HQ)
422
422 (Proxy)
422 (LT)
Should the Quality of Video be at 100 %
Sound = should it be uncompressed or should I use the pass Thru setting
Frame size = should I keep it native 720 x 480 (DV-NTSC)
Field Dominance = should I keep it upper field?
Should I deselect the following:
Interlaced Scaling
Reinterlace Chroma
thanks for your help
