conversions and transcoding?
scott robinson
on Nov 13, 2009 at 5:28:54 am
I was hoping to get some advice or tips from anyone who has had experience in converting square pixel video to non square video.
I have been using both Episode and Compressor but am wondering if this is even a possibility with either of these?
Just to make things more challenging, I have several of these clips in different resolutions and formats.
Essentially, we are have various codecs, 16:9 ratios and some square pixel videos, which we intend to bring into a PRORES 422 format with a 4:3,non-square pixel video space. Any help or suggestions would be much appreciated!
Daniel Low
Re: conversions and transcoding?
on Nov 14, 2009 at 1:15:18 pm
I'm not sure what advice you need. Converting square to non-square is a trivial matter as long as you keep to the correct frame and pixel aspect ratios.
"There's no chance that the iPhone is going to get any significant market share. No chance."
Steve Ballmer To USA Today: 30 April 2007
"We and Apple are neck and neck and we're chasing the two
other players,"
Steve Ballmer, referring to Nokia and Research in Motion. October 6th 2009
scott robinson
on Nov 15, 2009 at 12:30:14 am
So if i want to change the aspect and square pixel to non-square, can I do that with compressor in geometry or in After effects?
Let say I have a 1920x1080 with square pixel and I want to keep the entire video frame but get it into a 4:3 720x480 non-square pixel space... do I just letter box it with compressor and put the pixel settings as NTSC 601?
Daniel Low
on Nov 15, 2009 at 10:52:23 am
[scott robinson] "So if i want to change the aspect and square pixel to non-square, can I do that with compressor in geometry or in After effects? "
Either, but it'll be easier in compressor as part of the transcode process.
[scott robinson] "Let say I have a 1920x1080 with square pixel and I want to keep the entire video frame but get it into a 4:3 720x480 non-square pixel space... do I just letter box it with compressor and put the pixel settings as NTSC 601? "
Basically, yes.
other players,"
