Compression Confusion
Andrew Crittenden
on Nov 7, 2009 at 6:29:54 am
Is there a place anybody knows where I can study up on everything about video compression?
I'm constantly baffled. For instance, I just exported from a QT movie to FLV. The first movie was compressed at 400kbps (medium quality) The second at 700kpbs (high quality). The final file size for the 400kbps was bigger than the 700!
Does this make sense to anybody?
Andy
Andy
Daniel Low
Re: Compression Confusion
on Nov 7, 2009 at 9:47:36 am
Are they both the same length?
"There's no chance that the iPhone is going to get any significant market share. No chance."
Steve Ballmer To USA Today: 30 April 2007
"We and Apple are neck and neck and we're chasing the two
other players,"
Steve Ballmer, referring to Nokia and Research in Motion. October 6th 2009
Andrew Crittenden
on Nov 7, 2009 at 9:36:56 pm
Yes exact same video...
Andy
Daniel Low
on Nov 7, 2009 at 9:44:15 pm
Please detail the exact settings for both.
other players,"
Andrew Crittenden
on Nov 8, 2009 at 1:11:48 am
Original File:
QT Movie 641.8 mb
Dimension 1280 x 720
Codecs Animation, Integer
Duration 00:27
Total bit rate: 196,072
export Movie to Flash Video
Flash 8 Medium Quality 400kbps
Video On2 VP6 at 400
Audio MPEG layer III MP3 at 96kbps stereo converts to 2.2 mb FLV
Flash 8 High Quality 700kbps
Video On2 VP6 at 700
Audio MPEG layer III MP3 at 128kbps stereo converts to 3.1 mb FLV
Andy
Daniel Low
on Nov 8, 2009 at 9:57:24 am
I thought you said the 400kbs clip had a bigger file size?
other players,"
Chris Blair
on Nov 8, 2009 at 5:11:11 pm
Here are some past threads with great links to information about encoding:
http://forums.creativecow.net/readpost/20/863282
http://forums.creativecow.net/thread/20/863293#863294
If you do further google searches you can likely find even more info, although those two links provide pages of information from some of the most knowledgeable people in the insdustry. You could also do a search for onine articles by a guy named Jan Ozer, who conducts all sorts of tests on codecs and encoding software, and writes and lectures about it extensively.
But....even after reading all of that...(and I have several times over), you'll still occasionally end up having to experiment with settings depending on your source material and it's codec/format. There are literally thousands of format/codec combinations out there and each one has its own quirks, which makes it dicey to apply them globally to all video sources. Generally, the higher quality and resolution your source footage is, the better your compressed footage is going to look.
Chris Blair
Magnetic Image, Inc.
Evansville, IN
http://www.videomi.com
Andrew Crittenden
on Nov 8, 2009 at 11:20:13 pm
yes, i inadvertently flopped the two.
It's not a huge difference, but still....
Andy
Daniel Low
on Nov 8, 2009 at 11:53:04 pm
What are you using to to the compression step for you?
other players,"
Andrew Crittenden
on Nov 8, 2009 at 11:59:33 pm
Not sure what you are looking for. Taking a641 mb QT movie > File > Export > Movie to FLV
My computer specs follow:
Model Name: Mac Pro Mac OSX version 10.5.8 Memory 6GB 1066 MHz DDR3
Model Identifier: MacPro4,1
Processor Name: Quad-Core Intel Xeon
Processor Speed: 2.26 GHz
Number Of Processors: 2
Total Number Of Cores: 8
L2 Cache (per core): 256 KB
L3 Cache (per processor): 8 MB
Memory: 6 GB
Processor Interconnect Speed: 5.86 GT/s
Boot ROM Version: MP41.0081.B04
SMC Version (system): 1.39f5
SMC Version (processor tray): 1.39f5
Andy
Daniel Low
on Nov 9, 2009 at 12:04:07 am
Quicktime is crap at doing any kind of encoding. You really need to use dedicated software like Apple compressor or Telestream Episode. You'll never get consistent results exporting from QT player.
other players,"
