Help with best compression for web based showreel.....
Hamish Doyne-Ditmas
on Nov 3, 2009 at 3:06:19 pm
I am a cinematographer who is having their first website built. My webbuilder has asked me to give them all of my files which are commercials, music videos and shorts in small files that can be up loaded easily. I have searched the web but it seems difficult to find information as to which is the best way to go. I have access to Adobe Media Encoder and it seems that H264 is the best codec. My original files range from Quicktimes that range from 80-5GB in size (1280x720 pixels) and standard files (1024x576) and clips in a native resolution of (720x576).
My question is should I encode these files all to 720 x 576 in the quicktime preset and using the H264 codec or should I convert using H264 as the format itself or should I be using Flash encoding as that is how the website will be showing the spots,I want to keep the quality at its highest.. also is there an optimum size of file that will stream well... sorry I a newbie when it comes to technical stuff regarding compression...
Any help most appreciated...
Hamish
Craig Seeman
Re: Help with best compression for web based showreel.....
on Nov 3, 2009 at 3:38:36 pm
H.264 has been working in Flash since December 2007. Even .mov and .mp4 H.264 will work in Flash.
http://labs.adobe.com/wiki/index.php/Flash_Player:9:Update:H.264
Hamish Doyne-Ditmas
on Nov 4, 2009 at 9:53:24 am
Many Thanks for this link... so having read this should I encode all my work using the FLV F4V Format with the setting set to F4V Web Large Pal Source Flash 9.0 and higher....(in Adobe media encoder) and is that using the H.264 encoding as there is no mention of that in the settings panel for this format?
Many Thanks
Hamish
