Will pay for great compression. QT to FLV
Dan Schonberg
on Nov 3, 2009 at 12:56:51 am
I can't afford Sorensen or any of the good ones right now. Just spent my cash on After Effects and some other things. I do have cash for someone to compress my 9 lossless quicktimes into small FLVs. I am looking for someone who has Sorensen (or comparable capabilties) to pay reasonably for this. Or maybe just a kind soul to do it for free. I just need this done but cant afford Sorensen and AME wont make them small enough.
Cat Mayville
Re: Will pay for great compression. QT to FLV
on Nov 3, 2009 at 7:08:02 pm
I use cleaner--probably cheaper to buy that then to pay somebody. I can help you with settings once you get the software
Thanks! Cat Mayville
Craig Seeman
on Nov 3, 2009 at 7:13:29 pm
Cleaner is DOA/EOL. It hasn't been updated in YEARS (yes, YEARS!).
Dan Schonberg
on Nov 3, 2009 at 7:19:03 pm
Who makes Cleaner? Autodesk? How much is it?
Craig Seeman
on Nov 3, 2009 at 7:28:53 pm
Autodesk. $595. I strongly recommend NOT BUYING. VERY STRONGLY! It hasn't been updated in YEARS and it's increasing likely to have issues with current operating systems.
Craig Seeman
on Nov 3, 2009 at 7:15:20 pm
It's really not what I'd call a "professional" encoding app but it might get you through a project for less money that it would cost to have someone compress it for you.
DV Kitchen - $80
http://www.dvcreators.net/dv-kitchen/
Dan Schonberg
on Nov 3, 2009 at 10:58:02 pm
cool. i am going to look into this. may be the solution im looking for. hopefully they have a trial and I can see if it compresses well. if yes, im buying it!
Dan Schonberg
on Nov 4, 2009 at 12:08:36 am
so Kitchen wont make a quicktime into a flv because I encoded my quicktime with a non-kitchen compatible codec. sound right? jeez. so I have to go make a new qt with a different codec to test Kitchens ability to make a small FLV. whew.
Craig Seeman
on Nov 4, 2009 at 12:13:04 am
I haven't used DV Kitchen but maybe that's the difference between an $80 app and a $495 app. I'd assume it should work with some or most Quicktime codecs if you have them installed. I think there are iMovie and Final Cut users, who use DV Kitchen.
Dan Schonberg
on Nov 4, 2009 at 10:19:02 pm
Ok, until I get that figured out, I am still going to need someone to compress them for me when the project is approved.
Anyone willing to help an ambitious newbie out until I get my compression software.
Andrew Crittenden
on Nov 7, 2009 at 6:21:21 am
Hey, I'm still trying to figure out my way with all this compression stuff. On my Mac, if I open a QT movie, and then go to File>Export, a dialog box comes up "Save As." Towards the bottom of the box, there is a setting for "Export," which gives me several options including "Movie to Flash Video." Now I don't know if that's because of some software I've purchased along the way or not, but it's an option I have.
If that doesn't work, you can try sending me a video, and I can compress this weekend for you. Not really interested in money. Don't want to commit to the whole job until I know more about the particulars.
Anyway, hope my post helps.
Andy
Andy
