What is the Best way to convert SD-SDI to MPEG2 with H264?
John Pham
on Oct 31, 2009 at 1:52:23 am
Hi, how you all doing?
I'm trying to see what is the best way to convert my SDI signal to MPEG2 with H264 codec. Thanks
Chris Blair
Re: What is the Best way to convert SD-SDI to MPEG2 with H264?
on Oct 31, 2009 at 7:59:59 pm
Are you doing this in software I assume? If so, without more specific specs, it's hard to say. Depends on what computer platform you're on, what encoding software you're using, what codecs you have available with it etc.
If you're on Windows and have a mid-range encoding app like Procoder, they have lots of presets for compressing using H264 and using the MPEG2 container.
If you're on a Mac, others on the list can give specifics depending on what you have software wise.
But it really depends on the end-use of your MPEG2 file. Is it for broadcast? Does it need to play for a presentation off a PC? What's the audience for your file?
Chris Blair
Magnetic Image, Inc.
Evansville, IN
http://www.videomi.com
John Pham
on Oct 31, 2009 at 8:39:34 pm
This will be hardware...I'm sorry I didn't mention that. The SDI feed is from our playout system and I need to convert that signal to MPEG2, and I'm in the process of finding the best way for it to deliver. Thanks for your respond
Chris Blair
on Nov 3, 2009 at 3:12:07 am
For hardware encoding, look at these:
Digital Rapids http://www.digital-rapids.com/Products/IndividualProducts.aspx
Envivo http://www.envivio.com/
Visionary Solutions, Inc. http://www.vsicam.com/
Telestream http://www.telestream.net/pipeline/overview.htm
Matrox http://www.matrox.com/video/en/solutions/encoding/
My brain gets foggy looking at all the various options and weird names for the various hardware solutions. I know some people that use Digital Rapids stuff and it just plain works, is easy to configure, comes with software, and is pretty affordable considering what it does.
Many on the list tout Telestream, and I know a lot of TV stations use it in various configurations. I've read good things about Visionary Solutions and they have a slew of products, but their pricing and configurations are confusing.
The Matrox solutions require 3rd party software from what I've read, so you'd need Telestream Episode or Apple Compressor or others to get the hardware accelerated benefits of it. I don't believe it has direct input of video/audio either, but is an accelerator card.
There are probably other products too, but these are the ones that come up the most when in real-time encoding discussions.
Chris Blair
Evansville, IN
Chris Blair
on Nov 3, 2009 at 3:14:19 am
Here's a better link to Matrox solutions, which combined offer the I/O you'd need to encode from video decks, NLE, feeds etc.
http://shopmatrox.com/usa/products/categories.asp?CategoryID=83&Column=2
Chris Blair
Evansville, IN
Chris Blair
on Nov 3, 2009 at 3:27:58 pm
One last hardware based solution I forgot to mention is Viewcast Niagra:
http://www.viewcast.com/products-overview
Chris Blair
Evansville, IN
Daniel Low
on Nov 1, 2009 at 1:48:30 pm
http://forums.creativecow.net/readpost/20/862073
"There's no chance that the iPhone is going to get any significant market share. No chance."
Steve Ballmer To USA Today: 30 April 2007
"We and Apple are neck and neck and we're chasing the two
other players,"
Steve Ballmer, referring to Nokia and Research in Motion. October 6th 2009
John Pham
on Nov 5, 2009 at 8:29:05 pm
thanks Chris for everything =)
