VBR Encoding WMV with Sorenson
Andrew Saliga
on Oct 22, 2009 at 7:38:01 pm
I'm using Sorenson to encode WMVs for the first time and would like to confirm I'm doing the VBR encoding correctly. I'm trying to encode the video at 7-18mbps. I chose WMV 9 Advanced as the encoder and set my data rate to 7,168kbps and the max data rate to 18,421kbps (it's the closest I could get to 18,432kbps without going over).
-Andrew Saliga
Steelehouse Productions
http://www.steelehouse.com (undergoing a much-needed redesign)
http://www.vimeo.com/steelehouse
Daniel Low
Re: VBR Encoding WMV with Sorenson
on Oct 22, 2009 at 7:51:24 pm
[Andrew Saliga] "I'm trying to encode the video at 7-18mbps"
Wow that's pretty high, are you encoding 1080p?
"There's no chance that the iPhone is going to get any significant market share. No chance."
Steve Ballmer To USA Today: 30 April 2007
"We and Apple are neck and neck and we're chasing the two
other players,"
Steve Ballmer, referring to Nokia and Research in Motion. October 6th 2009
James Roche
on Oct 22, 2009 at 8:03:26 pm
very sorry wrong thread!
Andrew Saliga
on Oct 22, 2009 at 8:03:56 pm
Source is 1080 output is 720. My math is right though correct? 7mbs=7168kbps
I'm compressing FLVs, 2 flavors of MPEG-2s, 2 flavors of WMVs...at lot of different needs for this project. I know with this particular WMV compression it's going to be used for HDTVs.
-Andrew Saliga
Daniel Low
on Oct 22, 2009 at 9:13:50 pm
[Andrew Saliga] "My math is right though correct? 7mbs=7168kbps "
To most people 7 Megabits per second = 7000 Kilobits per second.
I you want to do VBR I'd aim for a peak of 14Mb/s rather than 18
other players,"
Andrew Saliga
on Oct 22, 2009 at 9:23:13 pm
Thanks Daniel.
As for the settings in Sorenson, the "Data Rate" section...I assume when doing VBR that is the average data rate? Is there no place to set the minimum?
-Andrew Saliga
Daniel Low
on Oct 22, 2009 at 9:52:54 pm
I don't use Sorenson but usually you set an average and a peak, the peak is usually not more than twice the average.
other players,"
Andrew Saliga
on Oct 22, 2009 at 10:58:37 pm
Thanks again Daniel. I guess if I stop and think about it, it makes sense that the peak shouldn't be more than twice the average.
-Andrew Saliga
