Conversion
Dan Newton
Conversion
on Oct 11, 2009 at 6:43:08 pm
Hey
I have two urgent questions which I need help in:-
1. I have been asked to convert a MOV to a mpeg 2
now the program I normally use is Sorenson Squeeze and Final Cut Studio Compressor ---
but I normally use Squeeze to do mainly mpeg One CONVERSIONS
I am not sure how to do a mpeg 2 conversion
here are the requirements:-
format: mpeg 2
width : 720
height: 480
crop to center: - 1.333:1
Padding: None
frame rate: 30 FPS
Aspect Ratio: 4:3
field dominance: automatic
average daTA RATE: 5 (MBPS)
MAXIMUM DATA RATE: 7.5 (MBPS)
Could you tell me the steps I would need to do --- to do something like this
2. I have a video (quicktime mov) which is a Pal format: 720 x 576
they have asked me to give it in a ntsc format -- both as 4:3 and 16:9
in NTSC format .
how would i do this if I was to export it as a quicktime movie as a 4:3 and 16:9 ---
please help
what settings would I set to make it in a ntsc format
Cheers
Daniel Low
Re: Conversion
on Oct 11, 2009 at 10:12:57 pm
[Dan Newton] "what settings would I set to make it in a ntsc format"
You use the settings they have supplied you, start with an MPEG-2 NTSC preset and adjust as they have told you to:
width : 720
height: 480
Padding: None
frame rate: 30 FPS
Aspect Ratio: 4:3
It's not going to look great as you are 'standards converting' from PAL to NTSC. Ideally you'd get your footage professionally standards converted first.
"There's no chance that the iPhone is going to get any significant market share. No chance."
Steve Ballmer To USA Today: 30 April 2007
"We and Apple are neck and neck and we're chasing the two
other players,"
Steve Ballmer, referring to Nokia and Research in Motion. October 6th 2009
Dan Newton
Re: Conversion
on Oct 13, 2009 at 6:49:24 am
Hey
Thanks for the feedback ---
when I use Squeeze -- the format comes as mkv or something
shouldn't it come with an mpeg output?
please help
Daniel Low
Re: Conversion
on Oct 13, 2009 at 7:30:25 am
[Dan Newton] "when I use Squeeze -- the format comes as mkv or something"
I'm fairly sure that Squeeze doesn't support the mkv wrapper. Are you sure that's it's not m2v?
other players,"
Dan Newton
Re: Conversion
on Oct 13, 2009 at 8:21:56 am
whoops my bad
yes m2v --- how come it doesn't have a mpeg output
Daniel Low
Re: Conversion
on Oct 13, 2009 at 8:31:59 am
[Dan Newton] "yes m2v --- how come it doesn't have a mpeg output"
That is MPEG-2. 'm2v' stands for "MPEG-2 Video".
Your audio will be encoded as a separate file ready to be taken into your DVD authoring application.
http://en.wikipedia.org/wiki/M2V
other players,"
Dan Newton
Re: Conversion
on Oct 13, 2009 at 11:07:13 am
Hey
ok two questions
1. I need to send the mpeg 2 to a client so they can view it on their computer and they only require mpeg 2 --- i don't want to send it to them seperately with the audio.
2. on squeeze there are numerous options ... I.E. lg, dvdlg etc... and when you are in the settings window --- do I set it on program or elementary and which option do I choose: lg, dvdlg etc..,
Please Help
Daniel Low
Re: Conversion
on Oct 13, 2009 at 12:45:22 pm
You need to output a program stream on order for the audio and video to be part of the same file.
Dan Newton
Re: Conversion
on Oct 13, 2009 at 9:19:13 pm
Hey
so what would the output normally be
will it be
.MPEG or .M2V
Daniel Low
Re: Conversion
on Oct 13, 2009 at 9:29:53 pm
[Dan Newton] "so what would the output normally be"
It depends on the use of the output, but it will never be .mpeg but rather .mpg.
MPEG-2 can have the following extensions depending on output type.
.mpg
.m2v
.ts
.m2t
.mxf
etc..
other players,"
