squeezed conversion 16:9 to 4:3
Lasse Laursen
on Sep 27, 2009 at 3:32:23 pm
I have a 10 second spot shot in Panasonid HD (960X720 50fps)
The client needs the final spot in the following specs.
Mpg2 program stream (audio and video together) field order B (.mpg)
720:576 pixels, 25 fps. (Pal DVD) 24 bit, 4:3
Gop: 1
Gop : 12
I-Frame distance: 12
Reference distance: 3
I have managed to find and adjust all of the above besides I-Frame distance, Reference distance and field order inside compressor. Are they possible to set from compressor?
The final question, and this might be a bit n00b, but when coverting my 16:9 footage (960X720 50fps) to 4:3 (720X576 25fps) my export gets squeezed. I want to keep the aspect ration and just have the exported mpg2 file letterboxed.
I hope i make just a tad of sense.
Best regards
/Lasse
Very nice forum )
Daniel Low
Re: squeezed conversion 16:9 to 4:3
on Sep 29, 2009 at 12:58:04 pm
720x576 can contain either a 4:3 or 16:9 frame aspect. Simply select 16:9 as the desired target in compressor, it'll look squashed until you view it through a DVD player, VLC etc.
"There's no chance that the iPhone is going to get any significant market share. No chance."
Steve Ballmer To USA Today
