Converting with Compressor
bree adams
on Sep 17, 2009 at 9:02:03 pm
I have never used the Compressor program. Please be patient as I am as green as they come.
I need to convert a 1080 HDV .mov to a 720x480 mpeg. One person needs it in HD and another an mpeg.
I imported the file into Compressor and exported to MPEG format but I did not see an option to make the frame size smaller so it is very stretched.
I would appreciate some guidance on doing this correctly.
Daniel Low
Re: Converting with Compressor
on Sep 18, 2009 at 1:50:01 pm
[bree adams] "I need to convert a 1080 HDV .mov to a 720x480 mpeg. One person needs it in HD and another an mpeg"
720x480 is an SD not HD frame size. MPEG can be either SD or HD.
MPEG1, MPEG-2 or MPEG-4?
If it's MPEG-2 you can't make the frame size smaller, not in compressor anyway.
So, HD (High Definition) is a description of something that is larger than SD (HD is usually 1280x720 or 1920x1080) but does not describe what format it's in. MPEG is refers to a group of standards that can be anything from sub SD to greater than HD
"There's no chance that the iPhone is going to get any significant market share. No chance."
Steve Ballmer To USA Today
bree adams
on Sep 18, 2009 at 7:00:34 pm
Thank you. I did figure out how to convert the files. My struggle is in fact a way to change the frame rate without re creating the entire project.
One station I work with takes the HD 1080.mov and use the RECODER program to turn it into an MPEG. I assumed they were changing the frame size but maybe not.
Is there a program that I could have the frame size conversion happen easily?
bree adams
on Sep 18, 2009 at 7:10:03 pm
I am brain dead. I just realized I can drag the file into After Effects and scale it down as a unit and export. This rain is getting to me.
Thank you very much.
Daniel Low
on Sep 18, 2009 at 7:27:42 pm
Please let us know how you get on.
