376 minutes in a DVD?
Gregorio Pellegrino
on Sep 2, 2009 at 4:12:53 pm
Hello,
I have to make a DVD from 376 minutes of video.
Is it possible?
I'm working on MacOs X, what's the best program to compress?
I have Apple Compressor, is it good?
What settings have I to set?
Greg
Brian Alexander
Re: 376 minutes in a DVD?
on Sep 2, 2009 at 9:24:28 pm
[Gregorio Pellegrino] "Is it possible? "
Sure, but quality will not exist.
[Gregorio Pellegrino] "I have Apple Compressor, is it good? "
Compressor is great but no compression software in the world is going to do what you're asking and be able to deliver a decent image quality at the original frame size.
[Gregorio Pellegrino] "What settings have I to set?"
If you had no menus (gfx, pics, etc) you might be able to get away with a bit rate of up to 1600 Kbps for video. This will leave a little (very little) room for audio.
If you're doing this for a client I'd dig a little deeper. You may find that they're needs and expectations don't mesh.
Good luck.
Brian Alexander
Sr Video Engineer
Freeman AVS
Gregorio Pellegrino
on Sep 2, 2009 at 9:49:59 pm
Yes I know that there will not be quality, but it is the video of a lesson, really static.
The problem is that in Compressor the bit rate is in Mb/s and the minimum possible is 2.0 Mb/s.
Thanks for your help,
Greg
Daniel Low
on Sep 3, 2009 at 6:07:06 am
Ah yes, you'll need to get Episode from Telestream to go to a lower bitrate.
"There's no chance that the iPhone is going to get any significant market share. No chance."
Steve Ballmer To USA Today
Daniel Low
on Sep 2, 2009 at 9:49:52 pm
You could use compressor and you'd get watchable quality (depending on your source format) but only if you used a Dual-layer DVD
Gregorio Pellegrino
on Sep 3, 2009 at 6:11:16 am
Ok, but I don't know if every DVD player could read a duble layer cd...
Daniel Low
on Sep 3, 2009 at 6:59:01 am
All DVD players support dual layer discs.
Gregorio Pellegrino
on Sep 3, 2009 at 5:21:56 pm
Ok, I'll make a DVD DL. But I have another problem, the smallest bitrate in Apple Compressor is 2,0 Mb/s that compress 175 minutes for layer, so for two layers 350 minutes; but I have 376 minutes, how can I do?
Greg
Daniel Low
on Sep 3, 2009 at 8:43:27 pm
Like I said, you'll need to use another application to get a lower bitrate, and I recommend Episode
Gregorio Pellegrino
on Sep 3, 2009 at 9:59:13 pm
Ok, I'll try!
Greghy
Gregorio Pellegrino
on Sep 4, 2009 at 5:54:53 pm
Is there an application cheaper then Episode, or free?
Greg
Daniel Low
on Sep 4, 2009 at 9:29:31 pm
Not that I know of.
Eric Olson
on Sep 16, 2009 at 1:14:33 am
There are two free encoders that can create compliant mpeg2 dvd streams
http://mjpeg.sourceforge.net/
http://ffmpeg.org/
Both will allow really low bitrates. At really low bitrates rescaling to 352x480 half-D1 frames can reduce compression artifacts and increase quality.
Gregorio Pellegrino
on Sep 8, 2009 at 11:20:54 am
What bitrate calculator do you suggest to me?
Greg
Andrius Simutis
on Sep 17, 2009 at 11:01:30 pm
You can do this.
If you use a DL DVD+R, your bitrate will be 2.7 for the video only, assuming you use a Dolby AC3 stereo track for audio.
This will look pretty bad in Compressor because it has a max of 2 passes. Using something that will do more passes will give you more opportunity to save some quality. I'd suggest Cinemacraft's CCE-MP encoder which works as a plug in to Compressor. It's $800 and does a good job, but I've never gone as low as 2.7 with it. 3.5 looked pretty good and that was fast action stuff with a lot of detail whipping by with camera pans and quick edits.
Keep in mind too that some DVD players may have trouble playing back a burned DVD-9, so your other option is to make this a set of DVDs and split the program over two or more discs.
