how to change the audio in a h.294 video
Giuseppe Mangione
on Sep 1, 2009 at 3:23:40 pm
I my computer works almost all night to convert a 10 minute HDV project into h.294 640x360 compressed video.
In the morning I realize the I have some issue on the audio... only the audio not the video.
What's the best and fast way to change only the audio (AAC format) in a already exported compressed h.294 video?
I used final cut and compressor.
Daniel Low
Re: how to change the audio in a h.294 video
on Sep 1, 2009 at 4:56:17 pm
How do you want to change it?
"There's no chance that the iPhone is going to get any significant market share. No chance."
Steve Ballmer To USA Today
Giuseppe Mangione
on Sep 1, 2009 at 7:45:20 pm
I have a quicktime video in h.294 video format and ACC audio, and I want to substitute the audio only.
The video master with the correct audio, is on HDV, and if I export again from the master, it will take a long time.
I tried to import the h.294 video in final cut, create a new sequence, change the audio. But Final cut works only with uncompressed audio. And If I export the sequence without changing format, FCP does it quickly but I have the audio uncompressed!
Daniel Low
on Sep 1, 2009 at 9:21:06 pm
FCP work with all sorts of audio, not just uncompressed but anyway, you can use QuickTime pro to do what you want:
http://www.apple.com/quicktime/tutorials/addmusic.html
and Here
