too big
Jules Watkins
too big
on Jul 13, 2009 at 1:40:07 pm
hi,
need to upload a file asap...but how can i get it smaller
right now 8 mins is 246 mb...takes absolutely ages to upload
using fcp express
settings
h 264
1024 x 576 (pal widescreen)
quality best
bit rate 3200
key frame auto
audio 16 mono
Daniel Low
Re: too big
on Jul 14, 2009 at 2:45:56 pm
Erm, pretty easy really.
Reduce the bitrate and the frame size.
Two years from now, spam will be solved. - Bill Gates, World Economic Forum 2004
Jules Watkins
Re: too big
on Jul 14, 2009 at 5:58:38 pm
hi
so what kind of bit rate is ok below 3400 ?? i keep the size big because then it looks better when played back full screen, also gives the hd button on you tube which isn't the case if I scaled down dimensions,
what do you do in this case?
thanks
Daniel Low
Re: too big
on Jul 14, 2009 at 6:49:56 pm
[Jules Watkins] "so what kind of bit rate is ok below 3400"
That's for you to decide. I don't know what the video is of, or what you'd accept for good quality but I've seen stunning 1920x1080 video at half that datarate.
Compression is all about making compromises. If you want a large frame size and a top picture quality then you need a higher datarate and as such it's going to take longer to transfer over the internet.
If you don't want to reduce the frame size and the video looks crappy below that datarate then either get a faster internet connection or go and make a cup of tea (or 2) while it's uploading.
