compressor de-interlacing issue
Hoss Sarbaz
on Jul 10, 2009 at 6:04:08 pm
I'm running FCP studio 2 (6.06 with Compresser 3) on a 4 x 2.5 Ghz Power G5with OSX 10.5.7.
I am trying to compress a source file is 10 bit uncompressed Quicktime video file to h264 for web streaming.
The problem is I can't get a clean progressive output file. I've tried everything from using de-interlace plug ins in FCP which works fine but in compressor the image gets blurred.
I tried dropping the raw 10bit file into compressor by passing FCP but still can't de-interlace it.
I turn on the frame control set my settings to progressive and drop down to best motion and such...but still comes out crappy resolution with interlacing issues.
if anyone has a solution please advise. No I don't want to get suggestions for buying plug ins or additional software, if thats your advice then please do not reply. I need a solution with out making purchases if there is one... thanks!
Daniel Low
Re: compressor de-interlacing issue
on Jul 13, 2009 at 9:16:11 am
More details please on the source and the target formats, frame size, format of the source, target dimensions FPS etc etc etc
Two years from now, spam will be solved. - Bill Gates, World Economic Forum 2004
