Compressor problem right off the bat
Brad Phillips
on Jul 9, 2009 at 1:15:38 am
I'm trying to learn compressor and after naming my "batch" I still get the same error
EMPTY BATCH NAME
You must enter a name for this batch submission. This is the name that identifies this submission in the Batch Monitor and the History window.
and of course...it doesn't submit the item..ALTHOUGH IT HAS BEEN NAMED!!!
So far...after using AUTODESK CLEANER and SORENSON Squeeze...I'm not too impressed with Compressor.
Any thoughts on what might be wrong?
Daniel Low
Re: Compressor problem right off the bat
on Jul 10, 2009 at 10:07:48 am
Do a search here at the COW, this has been covered many times.
Two years from now, spam will be solved. - Bill Gates, World Economic Forum 2004
