sorenson squeeze
chris mclaughlin
sorenson squeeze
on Jul 4, 2009 at 1:36:48 am
Hi I dont know if this is where I post this but here it goes...If I use sorenson squeeze to encode for DVD how do I achieve final output for DVD with 16:9....the footage I have created and imported is all 720x480 created in a DV NTSC widescreen comp setting in after effects 5.5...its exported as a quick time file as 720x480 with no compression. can I use the dvd 16:9 lg template in sorenson and set the aspect ratio to 16:9...i want the end product to be 16:9 on a widescreen tv and a widescreen computer screen
thanks
Daniel Low
Re: sorenson squeeze
on Jul 6, 2009 at 10:22:46 am
[chris mclaughlin] "can I use the dvd 16:9 lg template in sorenson and set the aspect ratio to 16:9...i want the end product to be 16:9 on a widescreen tv and a widescreen computer screen"
Yes, assuming your workflow up to this point has been correct.
Two years from now, spam will be solved. - Bill Gates, World Economic Forum 2004
