converting SD 24p to 720p24
Austin Paz
on Jul 2, 2009 at 4:21:19 pm
hello,
im am in the process of upressing some dvx100b footage i have via compressor that was shot in 24p and 30p. i have no problems with the 30p footage when i use the 720p60 conversion in compressor, but whenever i try to convert my 24p footage, it always glitches as it its trying to convert it to 30p. (or thats just what it seems to me at least). even if i change the frame rate to same as original or whatever it still does this.
any ideas on how to convert dvx 24p footage to 720p24 footage correctly? (im converting to dvcpro btw)
Thanks.
Brian Alexander
Re: converting SD 24p to 720p24
on Jul 3, 2009 at 3:47:38 am
Have you tried using another i-frame based codec such as ProRes?
Austin Paz
on Jul 3, 2009 at 5:07:36 am
i just tried prores and it works fine with that, but im trying to get all my footage dvcpro so i have an easier workflow
