Dvcam video 16:9 full Height Anam. with 4:3 safe area
sara petrai
on Jun 10, 2009 at 12:49:01 pm
Hi everyone,
I've a issue that i need to be sure before give it back to my boss.
I've done a commercial 720x576 (1.094pixel ratio) with an audio track.
now I've to send it to a channel and they asked it as
DVCAM VIDEO TAPE SUPPLIED WITH DVCAM VIDEO CONTENT.
ASPECT RATIO 16:9 FULL HEIGHT ANAMORPHIC WITH 4:3 SAFE AREA
AUDIO STEREO (2 CHANNEL LEFT AND RIGHT)
well I don't wanna get lost in something maybe easy but need someone to confir how to do it properly.
1) dvcam video content = is quick time - dv pal? (I'M USING PREMIERE CS4)
2) shall I change the aspect ratio of the project or just when I endcoding it? or maybe each clip?! I suppose the project should be 4:3 with the clip 16:9?!!
3)audio= each audio track is it already with 2 channel?! r shall i split it in other 2?!
please somebody answer as soon as possible please!!!
Love you all, always save my work when reading this forum!!
Sara
Daniel Low
Re: Dvcam video 16:9 full Height Anam. with 4:3 safe area
on Jun 10, 2009 at 3:33:14 pm
I'd post this in the Premiere forum for the correct workflow but in answer to your questions:
1. DVCAM is DVCAM not Quicktime (as it's tape) but it can be digitised or created or transcoded to using the Quicktime DV PAL Codec.
2. If the footage is 16:9 then your project should be 16:9 and so should the clips (1024x576) - when played back to DVCAM tape they'll be 720x576 FH anamorphic
3. The clips are stereo which is 2 channels (left and right), that's all they are saying.
Two years from now, spam will be solved. - Bill Gates, World Economic Forum 2004
