Compressor outputs to 640x480 instead of 720x480
David Crews
on May 28, 2009 at 5:41:13 am
This is probably something simple, but. . .
I'm trying to make a 720x480 Mpeg2 program stream file from a MOV that is 720x486. When I run the source through Compressor, the frame size in the inspector is dimmed, but it shows 720x480. The final movie, however, always comes out as a 640x480 size. I can't find any other controls or information on how to "tell" it to make a 720x480 output file.
Thanks for any insights.
David
David P. Crews
CrewsCreative
Post Production - Motion Graphics - Original Music
512.663.9669
http://www.CrewsCreative.com
Daniel Low
Re: Compressor outputs to 640x480 instead of 720x480
on May 28, 2009 at 1:05:49 pm
[David Crews] "The final movie, however, always comes out as a 640x480 size"
Is this when you view it in Quicktime player?
Check the movie properties cmd-J (not just the 'Information' - cmd-I) - You should find that the movie is indeed 720x480, just being displayed at 640x480.
Two years from now, spam will be solved. - Bill Gates, World Economic Forum 2004
David Crews
on May 28, 2009 at 1:41:05 pm
Oh, very interesting! I can't find where to see the raster size in the Properties window in QT, but I pulled the final mpg2 file back into Compressor and it says it has encoded bounds of 720 x 480, and display bounds of 640 x 480.
Thanks for setting my mind at ease on this.
David
David P. Crews
CrewsCreative
512.663.9669
