Advanced DeInterlacing Methods
Brian Alexander
on May 27, 2009 at 3:00:37 pm
Most of my material I record is 1080i ProRes. Deinterlacing is easy with Compressor; the fastest (and best quality) workflow is to stick with ProRes for deinterlacing, retiming and resizing before creating a distribution (h.264) movie.
I am in the process of analyzing different methods of deinterlacing and I must admit that this is really splitting hairs here, but I want to make sure my quality stays as pristine as possible.
I'm looking for any information that will help me with my qualitative testing (preferably IEEE material but any will do). I've been referencing http://www.100fps.com/ and using JES Deinterlacer http://www.xs4all.nl/~jeschot/home.html#DEI as a more advanced solution than options given to me in compressor for my testing.
I've been able to split and deinterlace fields in compressor resulting in twice the frame rate (59.94 fps) but only by guessing and testing. I can't find any documentation supporting which algorithm Compressor (QuickTime) uses to deinterlace: Blend, Weave, Motion Compensate, or Discard.
My one solid question for this post: When removing a field from an interlaced frame how does the frame get filled in with missing information? It's not line doubled (as far as I can see). Is it interpreted or drawn from the other missing field?
Any links to other posts, information or forums would help me in my endeavor.
Thanks.
Daniel Low
Re: Advanced DeInterlacing Methods
on May 27, 2009 at 3:52:53 pm
You don't mention the optical flow deinterlacing technique that Compressor uses for its highest quality method.
http://en.wikipedia.org/wiki/Optic_flow
Aside from this method and ignoring the drop field methods, progressive frames are completed through either averaging or interpolation. High quality method on deinterlace parts of the picture that have movement (motion adaptive).
Two years from now, spam will be solved. - Bill Gates, World Economic Forum 2004
