Audio click on wmvs out of Sorenson Squeeze?
Rich Catena
on May 26, 2009 at 6:34:27 pm
Hello,
I am trying to encode wmvs with Squeeze, and on the result file I keep getting a loud audio click at the head.
The clips are sequences I cut in Avid Media Composer v2.2.10. The sample rate is 48khz.
I export them as Reference Quicktimes, with AIFF as the audio type. I import the clips into Squeeze v5.0, and encode using a custom wmv preset with the following specs:
Audio: WM Audio 9.2, 32kbps, Sample Size 16, 32k sample rate, Stereo
Video: WM Video 7, 250Kbps, 320x240, 15 fps, keyframe every 300 frames, max startup latency 2
Here's the specs of the Avid I'm using:
OS: XP Professional version 2002 sp2.
Windows Media Player: v9.00.00.3250
Quicktime: v7.1.3
Has anyone else had similar issues? Any help or suggestions would be greatly appreciated.
Rich
Daniel Low
Re: Audio click on wmvs out of Sorenson Squeeze?
on May 26, 2009 at 9:51:30 pm
[Rich Catena] "Audio: WM Audio 9.2, 32kbps, Sample Size 16, 32k sample rate, Stereo "
Apart from the click the audio must sound pretty terrible, unless it's something simple like just speech?
I've often had problems with clicks when doing a sample rate conversion that isn't a divisible, like 48k to 32k. 44.1k to 22.050k always works!
Does the same thing happen if you choose mono rather than stereo on the output?
Two years from now, spam will be solved. - Bill Gates, World Economic Forum 2004
