DVD player won't play
David Benassi
on May 19, 2009 at 4:30:09 pm
Just burned my project onto a DVD 5, with highest bit rate compression. My dvd player is about 5/6 years old, so I'm sure I can't handle it. Just wondering if there is a general bit rate used in the industry that is sure to play on most standard players?
Craig Seeman
Re: DVD player won't play
on May 19, 2009 at 4:28:58 pm
It's hard to pin an exact number. The range seems to be peaks of 6.5 to 7.5. I take the more cautious road generally. The spec is 9.9 but that just goes to show how unrealistic a spec can be.
BTW I've seen cases where some encoders overshoot the peak so there's always some risk.
Daniel Low
on May 19, 2009 at 6:04:35 pm
Yes, a true 7.0 CBR plus audio plays on everything I've come across. Bear in mind that this is still a very high datarate and should only be needed for most demanding types of content.
Two years from now, spam will be solved. - Bill Gates, World Economic Forum 2004
