Encoding Flash from Compressor with CS4
tony lehoven
on May 9, 2009 at 8:01:15 pm
Hi All,
Quick question. Adobe CS3 would install a Flash component into QuickTime so that you could export Flash straight out of Compressor. It worked great and saved me the step of rendering a movie to export to Flash. I've recently upgraded to CS4 on a Mac Pro but now there is no QT component. For what it's worth the Adobe Flash encoder is now called the Adobe Media encoder. Is it possible to export Flash from Compressor with CS4? Can I install the old Flash exporter?
Tony
