Hi quality youtube files
Jennifer West
on May 8, 2009 at 12:00:47 am
Hello
I havent been able to get a good quality picture on youtube on a short video yet and have been trying different methods.
Both videos are short, 1 is 39 seconds with no sound and the other is 2 and 1/2 min. They have no sound - and are NTSC standard DV clips. Youtube recompresses them and they look awful.
These are the 3 methods I have used.
1) MPEG4 (using H.264 720 x 480 30progressive deinterlaced) exported from Final Cut Pro 6 using Compressor. these files are perfect when I have uploaded to a private web with no compression but looked horrible on youtube
2) Read on blogs to try this: FCP out with Compressor - same settings as above except using 640 x 480 H.264 as a .MOV file. Looked ok for first 10 seconds, then heavy pixellation
3) Standard QT out of FCP - obvioulsy did not work
I've been scouring the web and reading blogs and need to try to get to look just "okay" - not its looks horrible
I also have flash - should I important a QT movie into Flash and export that way?
How about this Compressor plugin that you can download - HQ Youtube setting?
thanks, Jennifer West
Daniel Low
Re: Hi quality youtube files
on May 8, 2009 at 9:21:44 am
[Jennifer West] "2) Read on blogs to try this: FCP out with Compressor - same settings as above except using 640 x 480 H.264 as a .MOV file. Looked ok for first 10 seconds, then heavy pixellation"
What exact settings are you using, datarate for example?
Two years from now, spam will be solved. - Bill Gates, World Economic Forum 2004
