Mpeg-2 audio to 44100 Hz
Robby Huang
on Apr 24, 2009 at 7:06:45 pm
Hi, so I need to change the format of my audio on an mpeg-2 file to 44100 Hz from 48000 Hz and I really have no clue how to do it.
I'm working on a Mac and basically is there any simple program to keep the video stream as it is and change the audio?
EDIT: Or maybe, how can I change the audio settings in Compressor for Mpeg-2?
Daniel Low
Re: Mpeg-2 audio to 44100 Hz
on Apr 24, 2009 at 10:33:14 pm
[Robby Huang] "so I need to change the format of my audio on an mpeg-2 file to 44100 Hz from 48000 Hz"
You'll have to transcode/re-transcode it.
Either re-do the initial AV transcode in compressor or demux using something like MPEGStream clip, re-do the audio to 48k and re-mux, again in MPEGStream clip
Two years from now, spam will be solved. - Bill Gates, World Economic Forum 2004
